Kia Soul 2016 1.6L (base model) automatic,
While doing random test with an OBD scanner I noticed that the LTFT values are too high on Idle, and are dropping significantly when the rpm goes up.
The dealership inspection found no air leaks, and no other problem. since the engine light did not turned on and no errors detected in their scanner, they say all is ok.
The attached excel contain the data from a short car drive with various driving conditions.
I dont have enough knowledge to know which values are normal and which are not.
are the spark timing values looks ok?
can anyone try to see which other values are too high/low ?
