Update: July 5th 2023
I finally got my car back from the dealership. They had it for 2 months and 3 days. I drove about 35 miles one way and back and did not get any errors, So I guess it is fixed. this is the result written in my paperwork.
" Electrical: Electrical related repair
C/S: Customer states Check Forward Safety System, (and all the others errors I have mentioned) Come on while driving.
Upon inspection no warning lights on. scanned for codes and has C272246 and C183186 as History.
after the pin tension adjustment and camera calibration the other code did not come back.
updated Tech line case and sent in info after what was done and was advised to replace front
camera and recheck.
Installed 99211 K0500 : Unit Assy - FR view CA
95895F02 Front Camera Assy, R&R 0.80
removed and replaced front camera and calibrated
road tested vehicle then rechecked for codes, No Codes. "
So
@michellemarini27 and
@Red5 those are the codes my car got and those are the part numbers of the things they had to fix.
My car was Filthy, layers of Dust and Spiderwebs all over the outside of car and dirty oily fingerprints all over the inside of my driver door plastics and dirty shoes scuff marks on the bottom of the door plastics and kick panel. They said let me detail your car for you before you leave. It took them 3 min they sprayed it with a hose. Still dripping and now mud dripping from the car with wet spiderwebs.
They did repair the dent they made in my door but did not fix the scratch on my door handle. before I showed up to dealership I got a low battery alert on my phone so I told them to check that. I do not think they did because it was not in my paperwork Nor is anything about doing my recall work. Nothing is written about the recall stuff they said they would complete. Never going back to that dealership I will drive 40 min to a different dealership for getting work done.
