I'm trying to install a line out converter. The radio I have is not the infinity unit. I need to figure out what color wire is which on the radio factory harness so I know where to tap into. Example - what color is left front - etc
I'm sure there is a warring diagram on line somewhere. It would make sense or so to me it would, that you would have that info before starting a project like this...
You might try searching radio connections, wiring, stereo connections opposed to "speaker colors"
the lights are either off the illumination lines or over the CAN control system it could very well be I dont know how the digital signaling works with that stuff to well. but you should be able to tap out the + and - of the speaker lines out the rear of the radio into your line converter. if you had a stock amp id say do it under the pasenger seat or int he trunk where the first gen puts the stock amps. maybe they still ran the harness's for that, check it out it should be in your cargo area for a gen I, and a gen II under pasenger seat.
heres a good source for the stuff you'll need to know -
