Hi everyone! I’m trying to figure out what the tapping noise is around the valve cover (sounds kinda like a Diesel engine). Sound is strong and loud only when giving engine gas (mostly uphill under load) and mostly during the first 45 min or so of startup (cold). Once engine is good and warm, it quiets down, but doesn’t go away now. Give enough gas to pass someone and you will hear it loud and clear. Can’t hear it at idle.
2012! 2.0 Automatic, 150k miles is about when it started to really be noticeable. I now have 175K miles on it. Meticulous about oil changes and maintenance. Use recommended oil in full synthetic changed every 6K. I drive like grandpa and never hard on the car. I start off slow to save gas. I was thinking maybe a stuck hydraulic lifter. Dealership is no help and recommended some Lucas Oil Additive which I did last oil change, but was no help. Anyone else experience this?? Any suggestions?
Thanks!
Kevin
Thanks!
Kevin
