Vibration at startup then it goes away
99 views 13 replies 4 participants last post by  Hank3
#1 ·
Upon startup this morning, my Soul started vibrating; I pressed on the gas pedal and it reduced, then I backed out of my garage and got on my way to work. It didn't vibrate any more at idle. I'm currently close to the 75k mile mark and have never noticed any vibrating right at startup after it has sat overnight. I have, however, experienced some very brief vibration at idle at the first stoplight out of my neighborhood, which is usually a couple minutes after startup maybe a handful of times in the past two years.
Spark plugs and air filter were changed 20K miles ago; air filter still looks pretty clean. Wondering what I should be looking out for in the coming days if it persists.
#3 ·
Good idea. I'll get the scanner out of my cargo area and have it handy for when it starts vibrating again next time. I have accelerated somewhat briskly a few times in the past few months onto the on ramp of my local interstate. But probably not full-on Italian style though.
#4 ·
I wonder if it might be some sketchy gas? What oil do you use Hank & when's the last time you ran Techron through the tank?
I would have the occasional rough idle with my 2014 too. Since switching to Restore & Protect, it's gone. But it's also only been warmer weather (meaning summer blend gas & no really cold engine) since using it.
#5 ·
Hey Geo - I typically fill up at Costo or the local Marathon here (both Top Tier and I will run Techron every 12-14K miles). I just used up my last Kirkland 5w-20 Full Synthetic, will be switching over to Kirkland 5w-30 FS in the next couple weeks.
#11 ·
If fuel system cleaner or an Italian tune up doesn’t help, I’d pull the plugs and inspect them to be sure. NGK counterfeits tend to wear very fast.
Here’s a site from NGK to help identify counterfeits.
I'm due for my annual/12-14k mile Techron service so that'll go in my next fuel up.
What I mean is, if counterfeit plugs is the source of your problem, I would have expected the symptoms would have happened sooner and been more obvious/severe.
I still would be pulling one out to inspect ASAP.
It's been approx 22k miles since I put the plugs in so hopefully they're not the culprit, but I'll pull a couple out tonight and report back. If they check out, I hope Techron and/or Italian TU will do the trick!
Thank you all!
#12 · (Edited)
I removed all four spark plugs, gave them all a wipe down and examined them all very closely with many images from the website rhysoul posted (as well as others from Google), and I'm fairly certain that mine are genuine NGKs. No subtle or glaring signs that they're counterfeit that I could see. I did however, manage to break a black plastic tab from either the wiring harness clip to the ignition coil, or to the ignition coil itself (was easier to pull the coil out with disconnected wiring on the coil next to the fuel line). Hopefully that won't cause any issues as the clip to the ignition coil is not as tight now - maybe it's a good time to get new coils (overkill?).
#13 ·
That’s good they seem genuine. It’s risky these days buying “genuine” auto parts from eBay or Amazon (unless you’re sure they’re an authorized reseller) that I don’t bother. Rock Auto has been pretty good though.
If it’s the little plastic tab on the coil connector, they do break pretty easy. I broke one last night, but the connector still kinda clicks in when attaching it to the coil.
Flatsole has a thread showing how to repair it using an inexpensive harness from the older 1.6L.
