Tire Pressure warning Light.
20K views 10 replies 9 participants last post by  ben2go
you can't be serious, you would be willing to loose thousands on a new vehicle because the TPMS sensor might not be working right!!!!!!!!!!! There is this thing called warranty to correct problems.
What did you use to verify that that 33 lbs was inputted and how do you know that is that accurate? Put in another 2-3 lbs and see what happens. Colder weather can reduce the psi in a tire but 34F is not really cold. Unless you exceed the tire pressure stamped on the sidewall of the tire, its unlikely you would blow a tire.
We don't have TPMS on our models in Canada - how will we survive! :sneakiness:
Conwelpic, I'm surprised you don't have TPMS in Canada. I though you get the safety related gizmos in Canada much quicker then we are.
we've had immobilizers (standard since the 2008 models) and DRL's which has been standard for over 25 years. Not so sure that TPMS is all that great of a feature from all the problems that appear to be associated with it. I survive the old-fashion way :sneakiness:
