I had my 2014 compute software updated by the racall and now the oil light is flashing but oil is full
B bwdz75 3,868 posts · Joined 2020 Add to quote #2 · Feb 17, 2021 Is it the oil light or the check engine light flashing? Oil light is red. Which recall did they do, did you have to leave the car overnight?
Gavin68 28 posts · Joined 2020 Add to quote #3 · Mar 3, 2021 Flashing oil light usually means the oil pressure sensor believes the oil pressure is too low (i.e. the fluid is too low). If you are certain the oil is full, try disconnecting the battery for a few hours and reconnecting it to reset the ECU.
Kerig3 1,094 posts · Joined 2019 Add to quote #4 · Mar 3, 2021 Mellie Joined 13 d ago Last seen 13 d ago
