Center console side panel removal
20K views 4 replies 5 participants last post by  bkimberly34
If its the same as my 2012, I have a center console box, open the lid, remove the 4 Philips screws, lift out the whole console tray, then you have 3(?) 10 or 12mm bolts way down inside there, use an extension. remove those bolts and the rear of the console will lift up, should be able to access your spilled items from the back.
