2021 Soul LX VIN KNDJ23AUXM77sssss
Shifting behavior changes dramatically with cruise engaged.
I'll try to suppress the rants.
Just want to know if this is normal for a 2021 Soul
or if it is something that can/should be fixed/adjusted.
Search results suggest it is common/normal.
MANY posts say they set gear manually.
But I swear the car didn't do this when brand new.
Started suddenly in mid-trip @ ~950 miles.
Admittedly I wasn't paying much attention before. (No need.)
Dealer said everything is fine.
(And that it was in Sport mode. Possible - leftover from a "test drive" the day before.)
65 mph. cruise off:
2200 rpm (7th) on flat or slight upgrade
2700 rpm (6th) on significant upgrade
3000 rpm (5th) only on steep upgrade
1950 rpm (8th) rarely/inconsistently on downgrade
65mph, cruise on
2700 rpm (6th) on flat
3000 rpm (5th) on slight upgrade (sometimes on flat)
2200 rpm (7th) rarely/inconsistently on downgrade
cruise still set for 65
press accelerator to reach 66
take foot off accelerator
2700 rpm (6th)
Another approach:
I normally use Drive mode as opposed to Sport mode
cruise off:
changing mode to Sport causes downshift/rpm increase
cruise on:
changing mode to Sport usually doesn't affect rpms
This would reduce my mileage from ~34 to ~27
So I set the gear manually.
But I must downshift on upgrades and don't have the best feel.
And in some circumstances I'd prefer not to deal with it.
I'm perfectly satisfied with the shifting behavior when cruise is off.
I'd like it to behave the same when cruise is engaged.
65 mph. cruise off:
65mph, cruise on
2700 rpm (6th)
Another approach:
cruise off:
cruise on:
