where is the fuse for it? I don’t see one inside or under the hood for it. It’s pretty cold here in the Midwest right now but I did try it on a 60 degree day and didn’t even hear the pump for the mist turn onCheck the fuse first. How cold is it where you live? Might just be fluid frozen in the lines. Lastly, check the motor. You can take a couple of test wires straight off the battery to the motor. Just be careful with the wires and don't touch the hot wire to anything but that switch.
According to a respondent to "Where is the windshield washer pump fuse on a 2010 Kia Soul?" it is the WIPER FRT fuse located in the inner fuse panel.where is the fuse for it? I don’t see one inside or under the hood for it....
On the Generation 2 Soul (2014 - 19) it seems to be attached to the reservoir so assume similar location on your Gen 1 Soul.So where is the actual washer fluid motor at in the engine bay? ...
