1 - 3 of 3 Posts
Finally figured out the correct coolant to use for my 2012+. Figured I'd do a drain and refill, so I got underneath the nose but can't find the drain plug anywhere.
Found a diagram online but it's so sketchy it's of no use.
Thanks!
Incidentally, pet**** is the proper term, but apparently, vBulletin thinks it's profanity. Yes, I learned it in the 70s from that notorious porn publishing house, Chilton's.
It's easier (and safer IMO) to un-clamp the lower radiator hose and pull that out (with a big drain pan below).
In the pic below, see the drain valve:
Be gentle, if that plastic breaks, you'll need a new radiator.
Also, if you move that old valve, it might not seal back properly and leak under pressure (hot engine).
1 - 3 of 3 Posts
