I believe there already is a forum about this. I will try to fini it for you and get back
I believe there already is a forum about this. I will try to fini it for you and get backanyone do anything to cover the spare tire and use the extra space for bulky object storage?
Was thinking I might be able to fashion something out of luan or something... Was wondering if anyone has done anything like that...
sorry, I cannot find it.....anyone?????I believe there already is a forum about this. I will try to fini it for you and get back![]()
thanks for searching...sorry, I cannot find it.....anyone?????![]()
I am in the same boat...anyone do anything to cover the spare tire and use the extra space for bulky object storage?
??! no spare? what happens if you get a flat?I just got a 2012 Soul. 2012s do not come with a spare, so I am using the space where the spare usually goes to store stuff. There is a small air compressor and repair kit already there.
I am planning on making a cover for the area above that out of plywood. That way I will have two compartments out of sight.
not a bad idea.I am in the same boat...
I was thinking use the bottom of the cargo organizer as a template and cut a sheet of MDF to fit.
Paint it black, cover the top side with the black carpet used on speaker boxes and the bottom side with felt or foam to keep it from rattling.
Really need to think it though...
-cmc-
-cmc-
Stitching / sewing is really not in my skill set... heh.not a bad idea.
if you cut bottom, then stitched pieces of that carpet together, you might be able to cover that, the well sides and possibly the 'top' (floor of cargo area) so its all one piece...
I thought of that. And meant to ask the dealer about it. Never really got to look since all he had on the lot when I bought mine were three Exclaims.if the base model dosent have the storage box and i assume still comes with a peice of carpet to cover the spare/sealant/pump.... could you not buy one of these as a starting point for your mods?.
Have you tried putting a full-sized wheel/tire in the compartment to see if it will fit ?Speaking of the spare, I am prolly gonna pull the donut that is in there and pick up a basic steel wheel from the import section of the junkyard and clean it up so I can run a full size spare.
I wonder how sturdy that is though...I saw this as the 'before' pic for an aftermarket cargo organizer.
Looks like I want the spare tire cover from the base model Soul?
Photo Gallery
Not yet. Of course I will do that BEFORE I buy anything...Have you tried putting a full-sized wheel/tire in the compartment to see if it will fit ?
looks good - but now you'll need a trip to the big-box store to find a finger-hole -I made a cardboard template and then cut a piece of plywood for the shelf.
I put two 1 x 2 supports on the bottom of it and painted it with undercoating.
