The lack of available performance suspension components for the gen1 Soul has got me to start thinking out of the box. The gen1 Soul and gen1 Veloster are both Hyundai / Kia PB platform cars. I'm already using a lower motor mount meant for a Veloster (perfect fit).
On a visual inspection the rear axle is very similar (the same?). I haven't gotten a chance to crawl under a gen1 Veloster with a tape measure, but I did look up some measurements online. The track width for the cars is only 0.5" different, which could be any number of components between the rear axle and the wheel (stub axle, hub, brakes, etc), so even if the axle is 0.5" off that could easily be made to flex into the bolt holes on each end.
I've only seen one rear sway bar for the gen1 Soul and it seems like a risky bit of e-bay mystery meat for about $350. I can get an Eibach rear sway bar meant for $140 on Amazon. Before I do a YOLO purchase and just see if it mounts / works, has anyone barked up this tree before? If so, how did it go?
Thank you.
Thank you.
