1 - 13 of 13 Posts
· Registered
Top Tier Gasoline Is Worth the Extra Price, AAA Study Shows - Consumer Reports
Top Tier Gasoline Worth the Extra Price, Study Shows
An analysis by AAA reveals that gas with detergent additives can keep an engine running smoothly
By Jeff S. Bartlett
Published July 7, 2016 | Updated March 2, 2022
A person pumping gas
Photo: iStock
Not all gasoline is created equal. There is plain old regular, and then there is regular gasoline that meets a higher standard, known as “Top Tier.” The difference between the two is significant, based on an extensive study conducted by AAA in 2016. Testing from that membership group revealed that consumers would be wise to factor the quality of the gasoline into their purchase decision, even if it costs a little more.
What Is Top Tier Gas?
Gasoline is essentially a shared commodity, often stored in common containers until it is purchased by a major retailer. After that, the retailer treats the gas with a specific additive, thereby giving the fuel its brand identity. But are these additives just a dosage of marketing hype?
MORE ON FUEL ECONOMY
10 Tips to Get the Most out of a Tank of Gas
Most Fuel-Efficient Cars
Most Fuel-Efficient SUVs
How to Decide If a Hybrid, Plug-In Hybrid, or Fully Electric Car Is Right for You
CR's Guide to Fuel Economy
Top Tier gasoline was developed in 2004 to go beyond the minimum standard for detergent additives to better protect increasingly sophisticated engines from carbon buildup and deposits on the intake valves—which can result in a rough idle, acceleration hesitation, knocking/pinging, and reduced fuel economy.
Over the past 20 years, engines have become far more precise, operating under tighter tolerances and at higher compression ratios, while targeting cleaner emissions and improved fuel economy. To achieve these goals, several major automakers—Audi, BMW, Ford, General Motors, Honda, Mercedes-Benz, Stellantis, Toyota, and Volkswagen—have united in support of Top Tier gas, specifically recommending it to their owners with the goal of preserving their engines’ original performance and emissions over time.
Keeping things simple for consumers, when a participating retailer sells Top Tier fuel, all octane grades from regular to premium gasoline and diesel must adhere to the Top Tier standards. So it is not necessary for drivers to upgrade to premium to gain the cleansing benefits.
A Ford 2.3-liter engine being tested on a dynamometer.
Top Tier Retailers
Retailers include 76, Aloha Petroleum, Arco, Beacon, Breakaway, Cenex, Chevron, Citgo, Conoco, Costco, CountryMark, Diamond Shamrock, Express Mart, Exxon, Fast Fuel, GetGo, HFN, Harmons Fuel Stop, Hele, Holiday, Kwik Star, Kwik Trip, Marathon, Meijer, Metro Petro, Mobil, Ohana Fuels, Phillips 66, QT/Quik Trip, Reeders, Road Ranger, Rutter’s, Shamrock, Shell, Simonson, Sinclair, Sunoco, Texaco, Valero, Value America, Wow, and Win Win.
Check this updated list of Top Tier retailers.
Intake valve comparison showing a new valve compared with valves after a 100-hour engine test.
Gas Test Findings
For the test, an independent engine testing lab that specializes in fuel analysis operated an engine continuously for 100 hours on a cycle to represent 4,000 real miles of use. The engine was then disassembled and photographed, and its key components were weighed and measured to determine the thickness of carbon deposits. Six fuels were used, randomly selected and split among three basic gasoline sources and three Top Tier.
The results showed that on average, non-Top Tier gasoline had 19 times more carbon deposits on injectors, on intake valves, and in the combustion chamber than Top Tier gasoline.
AAA also found Top Tier gasoline can have a cleansing effect, reducing intake valve deposits by 45 to 72 percent when used over a 5,000-mile interval. Variation in the results is attributed to the detergents used by different brands.
Further, analyzing gas prices over a 12-month period found just a 3-cent price difference between non-Top Tier and Top Tier gasoline.
Bottom line: For the nominal investment, this study shows that motorists would benefit from using Top Tier gasoline as their primary fuel.
· Registered
People buy the cheapest gas they can find.
What they don't realize is with name brand gas you get a little better gas mileage. I know this for a fact because I have experimented over the years. I've had people argue that gas is gas. Not true. I only use shell gas.
· Registered
By Jeff S. Bartlett
Photo: iStock
Top Tier Retailers
Gas Test Findings
Good article billy. Thanks! It just reaffirms what we've been preaching for years on this forum.
The only thing I'm not sure about is the statement near the end that the price difference between top tier and non top tier is about 3 cents a gallon. In my neck of the woods it's closer to 50 - 70 cents a gallon difference. Which by the way, with a full fill up, always seems to come close to the cost of a bottle of Techron.
Hence the old saying "you can pay now, or pay later."
Reactions: Hammerhead
· Registered
Here in West Virginia, the Top Tier and Non-Top-Tier gas prices are almost identical. We have Exxon, Shell, Marathon, and BP in our town and they are usually the same price as the off-brands.
Last week, we stopped at a Shell station (Top Tier) in Kenosha, Wisconsin and 87 Regular was $2.97. Most of the other surrounding stations were at $3.09 or $3.19. Go figure. LOL.
· Registered
Why does the pic have a green diesel nozzle? :rolleyes:
Green doesn’t always mean diesel, though it would be nice if pump colors were standardized. Usually gas is black in my area, but I’ve seen it green or red, maybe blue at some point too.
Gasoline Gas Fuel Machine Filling station
· Registered
Where I live in SE Pennsylvania, the only name brand gasoline that is top tier thatis available is Exxon, and those stations are few and far between. Everything else is Sheetz, Wawa, and Redners. None of which are labeled as Top Tier; although until a few years ago Redners gas was Exxon. I’m a firm believer in Techron in the tank every 3000 miles.
· Registered
Green doesn’t always mean diesel, though it would be nice if pump colors were standardized. Usually gas is black in my area, but I’ve seen it green or red, maybe blue at some point too...
Must be a local or maybe state thing. I think diesel pumps are all green here, but I don't pump it, so not 100%.
Seems like I saw yellow for E85, but that stuff is not common here.
1 - 13 of 13 Posts
