So I just spent 2 hours reading many of the posts regarding SSD's Performance Rails and Crossbars for 2010-2014 Souls. After having gone through them, I'm making the following assumption, among others: SSD makes a roof rail/rack for all Kia Souls 2010-2014, with or without a sunroof, excluding the 2014 Soul w/ a panorama sunroof.
I do have a several questions/concerns if you'd be willing to indulge me.
1) I saw one post discussing in great detail the fact that this is being anchored to the roof via a spot-welded piece of hardware that wasn't intended to carry a load. There of course was a rebuttal but the point is a good one. While SSD claims that there hasn't been a single incident in three years, that certainly doesn't mean there won't be an issue, whether it be by an installation or mechanical error. In any case, I'm highly concerned about carrying two kayaks @ 75lbs each up top over long distances and having them fly off in to someone's vehicle and killing someone.
2) If I drill a hole through the trim on the roof to accomodate the bolt that sticks through it when installing the SSD hardware, wouldn't this create a rusting issue to the car or the SSD hardware at some point?
3) What would the load capacity of the end rail/rack be or is that dependent on a specific hardware selection? (Sorry, I'm not knowledgable about vehicles or anything involving mechanical equipment in general. I'm secretly scared that the spot-welded anchor points are what holds the weight and that pushing those to the max will either cave my roof in or kill someone when it rips off my roof.)
4) From what I'm gathering from the SSD website, the cost to buy the rails and the crossbars is around $438 US + shipping. Is that what people are paying to add a roof rack and rails to their Kia Souls? Yikes!
5) Can other third party crossbars be used or does it have to be those ultra ugly Malones? If the prior, what are the restrictions/requirements? Again, sorry, I really have no idea what I'm talking about.
6) How would I go about finding a compatible kayak (or any clam shell) roof system to work with SSD's rail system?
7) Would I still have full open and tilt function of my 2010 Kia Soul sunroof with the rails and crossbars installed?
8) I also assume that once they're installed, there is no taking them back off and moving them to a new car, right?
9) I'm sure that MPG suffers when you have bulky items up on the roof. I'm curious if anyone has taken any notes on whether or not there is a noticeable difference between pre and post-installation of the rack/rails system or when it's under a load. Again, just curious.
10) In a response to a forum member's mention of the 2014 Soul's anchor points being real anchors meant to carry a load, SSD mentioned in response that they were "light duty at best." If those were "light duty at best," wouldn't that make these spot-welded anchor points "ultra light duty" and what does that really mean? As mentioned, my loads would range from 2 x 75 lbs kayaks to a large multi-gallon tub full of light camping gear (i.e. sleeping bags, etc), to a clam shell carrier.
Thank you all a ton in advance! We have a great community here!
