1 - 11 of 11 Posts
I took my wife's car to gas up then to the grocery to pick up medications for myself. When I got in the car to leave the grocery store I put the key in and it would not turn!
The light ring around it lit but nothing else. Not thinking much good I took out the key and flipped it over (silly I know) and nothing happened. It wouldnt turn.
So I sat there for a moment then was just about to have an anxiety attack when I had to sit down. I tried one more time, wiggled the wheel, put my foot on the brake peddle and it turned and started the car!
This is the only time it has happened in 2500 miles on her car. Never on mine (1200 miles). is this a fluke or portend a bigger problem looming? If I sit it in front of the service advisor and it works what is he gonna say? "It might be working fine sir" "Seems to be" "duh".
Any thoughts?
Perfectly normal with just about any car. Just a case of the steering lock actuating because of the position the steering stopped in. Wiggling the wheel like you did solves the problem and takes the load off the locking device, allowing you to turn the wheel.
This has been reported here a few times, but it sure isn't a Soul-specific thing.
well thanks. I am glad it was not something broken! She would kill me! (wife)
Read Only
This has happened to me also several times.
I tried jiggling the wheel alone but it did not unlock.
Called Kia dealer and they said to jiggle the wheel while turning the key.
That worked ok and has continued to do so couple times since.
Probably the best way to avoid it is to make sure the steering wheel is positioned at 12 o'clock high before turning the ignition off. That way there more than likely will be no pressure from the steering wheel lock. Easy peasy!
this has been going on ever since they came out with steering wheel locks - nothing new. Also its explained on page 5/7 in the owners manual :sneakiness:
I'll give you one worse than that. Back in the late 80s, my then wife owned a '77 Chevy Malibu. On this one particular day, she tried to start it. She then told me it wouldn't start and she handed me the key. I got in and turned the key; it started up right away. I then turned off the engine and handed her the key. She got in and turned the key; again, it just cranked repeatedly but wouldn't start. She got out and I got in and it immediately started up for me again. She and I both kept our feet off the gas and did it exactly the same way.
I've only heard rumors of people with powers like yours, the car whisperers......
The best way yo avoid this is to buy the Exclaim with Whole Shabang and you will have "Pushbutton" start.
I never take the key fob out!! :Yay::racing2:
1 - 11 of 11 Posts
