I will reply, just because this post was recent-ish & has no reply. Hi! I hope you fixed your issue. I am having the same issue. Unfortunately I can be of no assistance whatsoever, aside from moral support and the occasional comedic relief. So, everything worked fine, I had just recharged the a/c & it was cold!! Then I had to replace a coupler in the steering wheel. Once I got it back together, the a/c and heat, the controls for those nor the lights on any of it. I checked and replaced all the fuses before and after the issue, not a fuse in the inside panel. The blower comes on, but doesn't blow. The rear defrost works. I should also mention, when I say "I" did these things- I actually mean my ex did them. Its his car, which he was going to buy for me. Then, I ended the relationship, and if you ask him, that's why I do not have a Soul. So, now I'm riding passenger, it's getting cold out, and there's no heat, or front defrost. Hope you get better help, or that you figured out the issue and can help me to save my Soul from the cold. Good luck to us both & Thanks!!
