1 - 1 of 1 Posts
Did this a couple years ago, back during the SH days. Has been an awesome upgrade and is fairly easy for a home mechanic. I only know for sure that it will work on AM1 Souls (09-11) as mine is a 2011. Clears factory 16's but not the spare.
Started with dual piston calipers from a 2002 Hyundai XG350. (After 02 has a taller caliper that won't line up)
The rotors are from a 2002 Hyundai Santa Fe w/4WD. 11.53" Diameter (FWD rotors are smaller and will not work)
Totally bolt on, hardest part is bleeding the system after the swap. You will need to bend the rotor guard back away from the new rotor otherwise rubbing will result.
-Ryan
(DISCLAIMER: This information is provided "as is". The author of this information disclaims any loss or liability, either directly or indirectly as a consequence of applying the information presented herein, or in regard to the use and application of said information. No guarantee is given, either expressed or implied, in regard to the merchantability, accuracy, or acceptability of the information.)
1 - 1 of 1 Posts
