147k on my 2014 1.6L manual 6 speed. running good. only issues I've ever had were user wear and tear. I've been running full synthetic and changing about every 7000 miles (oil can claims 15,000). So I halved it, and use K&N oil filters because it's a lot easier to access/change with no shop to work in.
Swap out brake pads when needed, and won't hesitate to do an oil change at 3000 miles if the oil is looking bad. Every now and then I'll have to add a 1/2 quart but that's usually not unless I get close to 10,000 miles without an oil change. Also I've been running 5w20,*
I'll switch to 5w30 at 150k miles and see how that does then
I check my air filter every oil change and usually I just blow it out with the compressor, but it's never bad (pleasantly surprised actually). I use paper filters now that I'm in the desert instead of the k&n I used when I was living in the city.
I'm thinking next upgrade/tune-up I'm going to do will be new injectors & spark plugs and keep driving on from there..
I should do a radiator flush here soon though too.
little kirby got soul. still average 33-36 mpg, can get 42 in the right conditions
UPDATE
*I asked my old mechanic if switching to 5w30 instead of recommended 5w20 was a good idea. his response was "No..," not unless you're burning oil, i.e. visible smoke coming from the exhaust.
He said on these smaller engines and how they were designed/manufactured that it's not a good idea to use the heavier weight. However, in cold cold climates, it could be better. like Michigan/Montana cold.. Denver maybe.
Not sure if any of this update will help anyone but I felt I learnt sumthin' today...
