1 - 10 of 10 Posts
should i set the head unit settings to 0 when trying to set the powered sub's settings, or set the head unit to normal settings then set gain, boost, etc...?
thanks!! that is what i ultimately decided on. i wish the soul allowed us to keep presetting memory for each input type. the settings seem to differ dependent on what i'm listening to zune, usb, cd, satellite and radio.
you can't set them all the same 0/0/0?
I have preferences saved for each input type. You probably do too, but if you want them a certain way you have to set them
i don't know where to save the preferences for each input type. where is that found...? do you mean on the subwoofer or the headunit...?
Your head unit should be savings each input's settings as you set them.
So if you go to each input (CD,FM,USB,SAT, etx) and set them all to 0/0/0 they should all stay at that preset. but if you change say CD to 1/1/1 and then go back to it and it's 0/0/0 again the radio is not keeping the memory and you might need to have it checked out.
Discussion Starter · #7 ·
goodness, you are so right!!! i would automatically turn all settings to zero every time to adjust, never recognizing that the settings were exactly as i'd left them the last time. thank you!!
Discussion Starter · #10 ·
no, i had an amplified subwoofer installed.
the settings of the headunit are found by pushing the fat button on the right side of the radio.
1 - 10 of 10 Posts
