I had a bizarre incident last night. I was on a very steep hill with a stop light at the top of it. I have been trying to figure out how to use hill assist, so I tried something a little different while waiting for the light to turn green. I depressed the clutch pedal to the floor, put the gear shift in neutral, and applied the brake. When the light turned green, I tried to go into first gear. Surprisingly, I could only go into reverse (scaring the heck out of the MB driver behind me, which was sort of fun). I put it back in neutral, tried again, and had the same response. I then did it again, and was careful not to touch the collar which must ordinarily be raised to put the car into reverse. Same response. Eventually, I got out of the problem by leveling the car somewhat after letting it role backwards. Magically, first gear returned. The car seems okay, except that now there is a sound in the back which occurs when I accelerate and which sounds like a small rubber tube lightly hitting a metal part.
What happened?
What happened?
