I may sound young now but the only one who listens to am is my dad ha XDThe OEM bumper protector is extremely well made I had the dealer install it before I even picked up my car. It looks great. The Fin looks great but unless you don't care about AM if you are not in an urban area it cuts down on the AM signal too much.
Agreed! ... If I could disable AM and Sirus and only toggle through FM and BT on the stock radio I would be happy. I briefly considered the ultra cheap option of just unscrewing the antenna and calling it a day.I may sound young now but the only one who listens to am is my dad ha XD
The antenna comes with instructions, its a fairly strait forward stick it on top of the old one kind of thing.is there a guide for the antenna replacement yet?
It takes all of ten minutes to install, unscrew mast from roof antenna, clean surrounding area with an alcohol wipe, line up antenna, put a bit of masking tape down to mark the position, screw the sharkfin wire antenna to where you removed the mast, remove paper cover from double side tape and stick your sharkfin down.is there a guide for the antenna replacement yet?
Its mostly for looks. They do diminish certain signals depending on the arch. IE the taller the better but even then your covering your attention with a housing. AM is mostly effected. I suppose you could overcome this if could wire in a amplifier. Of course talking in theory.What is the purpose of the shark fin...just for looks or better reception?
I just joined and am seeing all sorts or topics that interest me.
Thanks
I replaced my antenna w/ a fin because I was tired of taking the antenna off every time we put the SUP on the vehicle. Works just as well as the OEM antenna and looks better in my opinion.What is the purpose of the shark fin...just for looks or better reception?
Thanks
