1 - 5 of 5 Posts
I rear ended some one in November. Relative Minimal damage. I put in a new radiator and radiator support and valve timing sensor. Everything else mechanical was ok. But then no spark. So we have tested every wire going from the coil to computer. All OK. All fuses have been removed and checked visual and with tester. Still no spark. Camshaft sensor works and shaft is rotating. Fuel pump kicks on. Rpms register when hook up computer tester. What am i missing? Is computer shot? Car just cranks over but thats all. Any suggestions?
Check the crank position sensor. If it was changed make sure it is seated properly otherwise it won't trigger and make sure the supply voltage is good. I believe its a hall effect sensor so you would need an oscilloscope to test the output. Thats where i would start anyway.
Thx I am going to check that this weekend i will get back to you. I didnt replace the crank sensor but it still might have moved when i hit.
your Drives info doesn't tell us which model you have ;)
1 - 5 of 5 Posts
