1 - 6 of 6 Posts
Sounds good , is the muffler in the center of the exhaust system ( the one directly under the driver and pass.seats ) still intact ?
No....that would be the resonator. I had it removed as well.
Actually .... On the 2014s and up , the muffler is in the center , and the resonator is at the rear . If you remove just the rear section , it makes it a little louder , but not dramatically .
That's why I asked if you just replaced the rear section with the muffler you bought, Or all of it , because it sounded a lot louder than I expected.
Everything from the cat back was removed. Then bent and welded in new pipe to the muffler. Then welded in the muffler.
That's why I asked if you just replaced the rear section in place of that muffler you bought . Or all of it , because it sounded a lot louder than I expected .
Sounds great 3rd. Since I'm in MO as well, I tried to invite you to a few fb groups that I'm in but was unable to. Always looking to cruise
1 - 6 of 6 Posts
