1 - 20 of 24 Posts
· Registered
My 2023 soul lx keeps nagging me, every twenty minutes, to consider taking a break.
I cannot find a 'reset' button for this item alone, after multiple searches.
Can a 'system reset' screw up things, or is there a shorter route to resolve this nag?
· Registered
I could be wrong, but I believe the car is reading your attention span, or lack thereof. If you continuously trigger the lane departure warning, the car thinks you need a nap.
Mine has never triggered, but I read...
go to set up
vehicle driver assistance
driver attention warning
disable it
· Registered
go to set up
disable it
I've disabled the attention warning, which does not list the break, but I've shut off the lane departure as well. At any rate, thanks for the suggestion; I have to take a ride again to see if this kills the nagging. I'll get back again to let you know the latest.
· Registered
Discussion Starter · #4 ·
Went for 45 minute drive with as many options I could affect switched off.
The suggestion to take a break kept playing
every ten or fifteen minutes, I think it was.
While I've seen the suggestion to delete or disable this command, the alarm tone,
in this particular vehicle there is not a visible option to
adjust, delete, deselect this option.
The alarm tone and display of a coffee cup pervades. Every ten to fifteen minutes, regardless of driving pattern.
Perhaps there was a short run of this irritating setup released. Of course, I don't know.
I expect this has to go to KIA CANADA for authorization or correction.
I'm certainly reluctant to go to the Franchise that sold it to me.
· Registered
Discussion Starter · #9 ·
RHYSOL
"I found this in the online “features and functions” guide, but I’m sure this is also in your owners manual. Does this help at all?"
___
Indeed, it is in my manual
___
Well, it helps define what I'm not seeing;
in that Driver Assistance,
Driver Attention Warnings has only the one singlular option; that being
Leading Vehicle Departure. (On or Off.)
My son suggests that pehaps there were a few renditions of this software cluster, and that with my particular 'update', no further menus were applied. We may have other people whining, though, eh?
He further suggests that perhaps there's a 'firmware update' available, but I don't know how to find that. Thing is, I don't want to lose other features or have them as non-functional. Switching off the sound and image are possible workarounds, but I actually don't recall repeated experiences of this in the initial days of use of the vehicle.
Nor can I imagine any setting being so terminal as to have had this effect. I mean, if I could turn it off, I should be able to restore to default. ... ... unless ... some interloper used my local wi-fi to hack me ... ? .
This "take a break" feature, unadjustable as present, is probably the lead feature I wanted.
Otherwise performance, in my experience of this car, is outstanding. I love it.
· Registered
Discussion Starter · #10 ·
RHYSOL
___
___
In Canada, we might start a whole series of jokes, because this car was brought to me from Quebec (Which, if I give it free reign, the car may want to race home. I'd be happy for that, as some of the most beautiful scenery and culture is in Quebec. Google: Saguenay Fjord.)
· Registered
Discussion Starter · #11 ·
This is the Dash, showing what I get:
RHYSOL
___
___
· Registered
Discussion Starter · #12 ·
Well, DANG !! The google reference there is supposed to link to my photo of the dashboarD cluster menu. - FAILED
· Registered
Discussion Starter · #17 ·
On a hunch that may or may not work. When was the last time you cleaned your wind screen? The system can't work properly if it can't see.
Thanks for this thought.
I haven't been zealous 'bout cleaning the windshield. However, I did take the car to the coin wash yesterday, and after that there was no change. It's worthy to note, though, that my understanding is that these operations' wax can interfere with wiper blades and the windscreen. So I try to avoid getting wax on the windshield. This means I may have not cleaned the windshield. That becomes the next task.
In this regard, though, I had the car tell me, on my first drive in a snowstorm, that the camera was blocked. The wiper cleared 'the block' and it went into normal mode. This makes me believe that if the screen is dirty, the car will (what has our society come to?) tell me to clean up my act; which it did not. Can't hurt to give it a wipe.
In the olden days, when I was young, the hot rod set used to say " A wipe a day keeps grime away ". I've also won a few bike show plaques for knowing what a clean machine is. My mechanic lowered my charges, too, I think because he saw an immaculate engine room.
· Registered
Discussion Starter · #19 ·
My understanding or misunderstanding is that the driver attention stuff is supposed to reset after the car's been shut off for a while; however, it hasn't reset.
· Registered
Maybe Canadian model doesn’t let you turn it off? I don’t know why the settings would be different than what I posted the other day (from the US owners manual). Maybe someone with a 2023 Canadian model can try and see if they can shut theirs off.
1 - 20 of 24 Posts
