Actually you can. They only problem is most shops will not do it and you will probably have to do it yourself. I installed it on my old car and it wasn't too difficult.No you can't do a r/start on a manual. There is a clutch pedal switch, that won't let the car start unless the clutch pedal is depressed.
Remote start allows you to get into a warm car in the winter and a cold car in the summer.it might do as long as you don't park it in gearbut there must be a type of lockout if you do!
Personally I don't see any reason for a remote start, I just don't see it serving any purpose other than costing you to install and to operate. But to each his own!
As mentioned above, MT models have a switch that requires you to depress the clutch pedal in order to start the engine. Using a remote start on one requires defeating said switch, therefore allowing the starter to turn with the clutch pedal out. If the car's in gear, that means it could lurch/accelerate unattended. There are ways to reduce this risk, but that just adds more complexity.I don't see why not. I mean, the mannies start up just like the autos, no?
But I don't have a manual, so I could be wrong...
I'm aware of that but this is why I don't agree with that, in cold weather the engine warms up far quicker when its driven not when its idling. It even tells you in the owners manual to not idle it very long even in very cold weather before driven away slowly. I have the heated seats which functions much quicker than the engine heater, so that keeps you warm while the engine temperature gets up to its proper operating temperature.Remote start allows you to get into a warm car in the winter and a cold car in the summer.
It also lets the engine warm up before speeding off which is a good thing, especially during the cold months when the oil is thick.
While I agree with you, I would like to point out that anyone with "HTX" as her location needs to try saying that after spending a winter up here in the 8th coldest city in America....you don't need a remote start in order to get into a warm car. Just walk outside to the garage and start the thing up, LOL. Then let it warm up. Who knows? You may even burn a few extra calories in the process...
And thanks for the informative explanation, fatabbot. I'm learning more and more about these complicated transmissions eveytime I get on here. Lol.
[Sent from my HTC Inspire via AutoGuide app using Swiftkey 3 Beta. Pardon errors.]
When it drops to -20F, it's nice to get into a car that is at least warmed up to 0F.
Or am I just innocently unaware? I began saving my pennies for the day when I can have a remote start, keyless entry installed on my 2012 Soul. Probs is, it's m/t - can't install remote start on a Manual Transmission, can you?
I vote 2015 !I think it is time for a 2015 Soul Exclaim!
