1 - 6 of 6 Posts
Hi, I been away a long time, but have a problem I can't seem to fully pin down.
I have a 2010 Kia Soul with stock 1 CD, BT radio with subwoofer, amp and lighted speakers and suddenly about 3 weeks ago the radio would not shut off. I thought no big deal no way it would drain the battery as it was new, but sure enough even after 3-4 hours it goes dead. The battery is less than a year old and checks out OK so the drain must be pretty big whatever is going on.
I thought it might have been the Sirius firmware bug, so I cancelled Sirius and it still kept happening. I thought maybe an ignition switch or door jam problem, but everything else works fine even the 2 cigarette outlets.
The only way I got it to stop was pulling the single 15 amp radio fuse on the driver side panel.
Since then the car works fine, no problems at all, except no radio.
I am thinking to buy another one off Ebay for about $100, but before I did I wanted to ask here. Its obviously something to do with the radio system, but is it the radio, amp, speaker lights, etc......
I would bet the headunit failed like mine did a couple of years ago.
I can replace the radio with one from Ebay for under $100, but would that cause the battery to drain so quickly?
I know very little about this, and trying to avoid the troubleshooting cost at the dealers.
I would take the risk Rk & put the $100 ebay radio in. My logic (which is questionable at best) is that there is something very wrong with a radio that will not power down & that leads to a dead battery.
Another option is just pull the head unit out for a few days & see if the battery drain stops.
I bought one from Ebay says it fits my Soul, looks identical except I get no sound from it. Sound does work, only not with the new radio.
Only difference is mine says B-15 on the top front and the replacement says B-13. I can not seem to find out what that means or if it matters?
Anyone know?
1 - 6 of 6 Posts
