Did the first oil change on the wife's 2016 Soul today. Used the Kia filter, and the one little thing that maybe I'm overthinking was....the oil level was still maybe 1/8 below "full" on the stick. I put in 4 full quarts, and had 8 ounces in one of the empty quart bottles, and put most of that in as well, and it calls for 4.23 quarts, so I knew I was close. After I warmed it up, and let it set a bit, checked it, and it was a little over halfway between L and F, on that flat part of the stick, so I put the rest in, which I knew was definitely right where it should be, if the quart bottles and once measurements are accurate. It's still maybe an eighth below the F, so do I call it good, or make sure it's right at the line, or am I overthinking it? I've changed my oil on all my cars, all of my life, and I usually don't get quite that ocd, but it's my wife's car, it's only 6 months old, and I'm just being extra careful. It's not "exactly" full, and it's not low either.....so what do some of you think?
Thanks in advance!
Thanks in advance!
