1 - 16 of 16 Posts
· Registered
I've already cleaned the IAC Valve and throttle body + Idle relearn. Still same problems encounter
Based on Obd2 readings Idle was 682rpm, When A/C turned on it goes to 588rpm, then goes back to 657
Idle/A/C Off
Light Font Line Red Electric blue
Font Line Red Electric blue Circle
The Engine and transmission support was already changed last Dec 2022
· Registered
Idle 682, ac on 657 that’s only 25 rpm. What’s the problem? it sounds normal.
(instead of updating your original post, just post a new one in this thread. Makes it easier to follow rather than going back to the top every time you change something)
1 - 16 of 16 Posts
