1 - 4 of 4 Posts
Hey guys and gals. I’m new here and there is a TON going on here. I apologize if their is an answer to this deep into the thread count here.
question:
I live in Guatemala and visit villages with ruts quite often on the dirt roads. I’d love to get a little extra lift on my Soul just by changing tire sizes. I guess I could do rims too if needed?
The car was brought in from the US and I bought it from a random guy. I’m not sure on the model. It does come with OEM standard aluminum alloy rims(if I even said that right!). The tires are lower profile, but look to be standard for the year and model.
thanks for any help!
I have 205/55r16 alloy which is my factory size. On my driver's door, when standing with the door open there is a label that lists original tire size.
Reference guide for car wheel and tire dimensions such as size, offset, PCD has some interesting tools and information.
The part I know that might be helpful is the first number is width in mm, the second number is aspect ratio, a percentage of the height, and the third is rim diameter.
In the US tires have weight and speed classifications.
The website referenced will convert tire diameter to standing height.
A 195/65r15 (base trim steel rim) has more sidewall than a 205/55r16 (+trim alloy rim) but is not actually taller.
632mm vs 635mm.
The tool will allow you to enter measurements from your car and make suggestions about what to buy.
good point eGAK, the speedo will not read correctly without modifications which are complicated and involved.
anytime I drive something with a suspect speedo I use a secondary GPS based item. Tork app ( free version on smartphone ) or Garmin.
1 - 4 of 4 Posts
