I'm having the same issue with my 2013 2u - all of a sudden both low beams are gone, high beams still work - checked fuses, there's a H/LP LH and H/LP RH 10amp fuse in the engine fuse box, and H/LP and H/HP Relays - fuses are good, swapped the relays, still no low beam, high beams still working. Seems to also be an issue with the right rear tail light connector at the taillight assembly as I was having issues with taillight, backup light alternating with the turn signal light when the right indicator was on, and only when the headlghts were on. appear to have the taillight issue bandaid fixed for now. but still no lowbeams.
Still under warranty until October 2018...
Ideas?
