1 - 12 of 12 Posts
Went to upgrade my new 2011 Soul (! w/2.0L), and dropped the socket down the spark plug hole. It doesn't seem to be all the way onto the spark plug, but stuck in there pretty good. Had bent up a brass coat hanger - got it stuck onto the bottom of the socket (by poking it through the hole (its an impact sized socket) - only to shear the hanger in half from pulling up so hard. One mechanic I know says that I'll have to remove the head to get it out . . . any other ideas?
So is it stuck because you didn't use a deep well socket and you can't get an extension into the socket?
Or is it that socket is stuck inside the tube on the plug? Honestly, I don't know what it could be catching on since the tube is smooth inside.
Did you try using a magnetic pick up to trying pulling it out?
Got it
Sprayed down the hole some PB (as the socket wouldn't turn), waited an hour and then slowly kept cranking on it with a ratchet wrench - held at a slight angle and gently pulled UP. Kept popping off, but slowly raised the socket out.
It was stuck, as it wouldn't even turn.
Excellent news that it came out. Were you using a standard deep well socket or a plug socket?
Because of the newer designs with the plugs buried in the head. You may need to use a plug socket. Or maybe the socket you used has a weird O.D that caused to get it bound in the sleeve?
Did it feel tight on the other cylinders or was this the only one you tried?
what "upgrade" were you doing?.... i thought the spark plugs were good quality already and were designed to last at least 60k?
Glad you got it out! But please use the correct socket.....impact sockets generally have a thicker wall making the diameter to large to go in tight areas. :)
Good advice about using ONLY spark plug sockets. Others
don't have the protective sleeve inside for the ceramic insulator
on the spark plug. I always recommend staying with the OEM
plugs. Their engineers work long and hard finding the right fit.
Other brands could run at the wrong tempatures and can be
a slightly different thread. Don't take a chance.
I do recommend changing the plugs more often and/or using a
small amount of never-sieze on the threads. I take out the
original plugs and put a small amount of anti-sieze on the
threads to make sure you can get them out. Be carefull and
don't get any on the electrode or ceramic insulator.
1 - 12 of 12 Posts
