1 - 17 of 17 Posts
Nice upgrade! How'd it go?
I ordered them on Amazon for $225 and had an aftermarket shop install them, Had to hard wire the accessory lights to a separate source which costed $150. Over all it was well worth it. It definitely updates the cars appearance. Eventually i'm going to repaint the car.
These look great. Where did you get them? I'm trying to find a pair for a friend's 2012 that I've been working on, but all the ones I can find say they only fit 10/11 models.
Sent from my LM-G710VM using Tapatalk
Discussion Starter #11
I believe 2013 was 2nd generation and the headlight design may be different. Therefore the aftermarket that was designed for generation 1 will not fit generation 2 . I would do a little research before ordering. The box it comes in is huge due to packing and would be a bitch to return.
Good luck
Good luck
Ugh, typo. It's a 2012 we're looking to do, not a 2013. My mistake.
Problem is we're trying to find an upgraded headlamp set for a 2012 and I'm coming up empty. Does anyone have A link to something that would fit?
If you're looking to install those black headlights into a 2012 or 2013 you're out of luck.
The 2012 changed the hood 1/2 inch forward and the cut on the bumper is lower as well. (Bigger turn signal light)
If you have the basic set of headlights, getting the exclaim projector ones should be the best fit for your car.
I've checked CarID, I use them a lot for reference and parts, they only have stock replacements.
1 - 17 of 17 Posts
