Does it use oil? If so how much?
Sounds like a stopped up converter.
I thought I was supposed to replace the coils when I replaced the plugs??? That's the only reason I replaced them. If it was a plug / coil problem, wouldn't I be having the same problem even at lower speeds and not just when I try to go up a hill or sped up to get on the highway?I don’t like Autolite spark plugs in Korean engines. They should be NGK. But that’s probably not your problem. If you had no problem beforehand, maybe the aftermarket coils are junk. Wouldn’t be too shocking with the poor quality aftermarket parts these days. Why did you replace the coils? If you still have the originals, put them back on and see if that helps.
Otherwise, it could be the cat. Oil burning will eventually cause the cat to go bad.
Coils don’t need to be replaced unless they’re bad. And sometimes aftermarket ones are worse than the old original.I thought I was supposed to replace the coils when I replaced the plugs??? That's the only reason I replaced them. If it was a plug / coil problem, wouldn't I be having the same problem even at lower speeds and not just when I try to go up a hill or sped up to get on the highway?
No I fought the law and the law and the law run.I fought the law and
the law won.![]()
sound to me like your catalytic converter is plugI have a 2015 with the 2.0 engine. It's starts and idles just fine. I can lightly step on the gas and it will eventually make it up to 60. But if I step on the gas even a little too much, there is a few second delay then the car bogs down bad and sputters. If I keep in the gas it will rev high and start knocking. It started doing this shortly after I replaced the spark plugs and coil packs. The first time it did it, there was a misfire code in cylinder 1&4... but after that code was cleared it has not thrown another one, yet still has the problem. Any ideas what it could be??
I recently saw and had fixed similar symptoms on my 2014 Soul Base. Ended up being some really cruddy valves. So much crud was caked on. Valves were walnut blasted clean, new spark plugs, new fuel injectors and new manifold seal. Amazing how well the car runs nowI have a 2015 with the 2.0 engine. It's starts and idles just fine. I can lightly step on the gas and it will eventually make it up to 60. But if I step on the gas even a little too much, there is a few second delay then the car bogs down bad and sputters. If I keep in the gas it will rev high and start knocking. It started doing this shortly after I replaced the spark plugs and coil packs. The first time it did it, there was a misfire code in cylinder 1&4... but after that code was cleared it has not thrown another one, yet still has the problem. Any ideas what it could be??
