1 - 20 of 72 Posts
Vendor
Kia Soul Fog Light LED Replacements
We carry LED bulbs for replacement of your Kia Soul fog lights, in all major sizes. They are available in HP, XP, and XML styles. This will make your Soul's fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Brightness:
Diode Dynamics offers several bulb model options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
HP48: 265 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
Bulb Design
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Kia Soul Model Year).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Fog Light LEDs for 2010-2013 Kia Soul (pair)
Fog Light LEDs for 2014-2016 Kia Soul (pair)
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
How much brighter is the 1430 lumen bulb compared to a Putnam 1250 lumen bulb? Would the 1430 bulb be whiter light?
Vendor
Hello,
Thank you for asking
Our XML2's are 1,420 lumens measured, which produces a significant increase over the factory halogen bulbs. I assume you are referring to Putco? They also make a fantastic product
Feel free to give us a call if you have any questions: (314) 205-3033
Nick C.
Can you check what yellow fogs I got from you ? One is dead
Well I think Nick c is gone from DD but , I contacted Diode Dynamics because one of my year + old yellow fog lights from them went out and they sent me a pair of there new brighter ones at no charge ! Kudos to Diode Dynamics . Great customer service ! IMG_5677.jpg
1 - 20 of 72 Posts
