I have no idea if this works on earlier models, but I know it works on 12 & 13 because I have both.
I have 2 base models. Both of them came with only 1 power port in the front. I would rather have 2.
I ordered the 2 power port piece from a guy on Ebay, and it came complete with the USB and Aux jack. You can order the part from Kia as well, but I'm unsure if you'll get the center section.
Anyway: once you have the 2 power port piece: Pop out the 1 power port piece from your dash. You *do not* have to pull off the shifter bezel or anything around it - this piece will clear everything. The easiest way I found to pull this out with the single port is to put your thumb in the port (make sure the key is off!) and pull out some. That will just slightly pop out the right hand side. Then get a piece of tape and wrap it around a small flathead screwdriver, and put a rag behind the screwdriver. Pry out and the power port will pop out.
Pull it out far enough so you can unplug the connectors. The USB connector has a small push pin on the bottom in the center of the while plug, push in on that while pulling the plug away. The power port has a small plastic tab on the bottom terminal that you need to push in while pulling away from the connector.
After you've done this, reach inside along the wiring harness. You will feel the 2nd power port wire in there, it is taped to the wire harness. Pull that piece of tape off and you'll release the 2nd port connector. Connect all the wires to the new port setup and *TEST EVERYTHING* before you pop it back into the dash - both power ports, the USB, and the Aux jack. The key has to be on for the ports to work, both of them are this way (one day I'll fix this as well). After you're done, line up the port with the holes in the dash and push straight back until you feel it pop into place.
Finished! You now have 2 power ports. This whole job, start to finish, including testing everything, took me 10 minutes. I paid about 40 bucks for a used power port setup on Ebay. They were around 100 I think at the dealer.
