A forum member made a cover - See Posts #9 & 13
A forum member made a cover - See Posts #9 & 13Hi, I am new to the forum can anyone help my 2020 kia soul didn't come with a cargo panel and I was wanting to make my own ..does anyone know the measurements including thickness of the board I should use ....thank you just trying to get ideas
Heavy duty.I'd use 3/8" thick plywood. If you're planning on putting a lot of weight on it 1/2"
The factory package trays are just plastic wrapped in felt. Basically a place to put bread and eggs.Hi, I am new to the forum can anyone help my 2020 kia soul didn't come with a cargo panel and I was wanting to make my own ..does anyone know the measurements including thickness of the board I should use ....thank you just trying to get ideas
The width is approximately 40 inches wide. The circular cut-outs at the leading edge is 2.5 x 1.5inches. The front part depth is about 15.5 inches. Piano hinge is mounted on that line. The back part is10.5inches. I made a cardboard template for this piece to match the curves. I used a 48 inch piano hinge ,cut to 36 inches to attach both pieces.I used a 2 inch hole drill for a handle to open lid.I made mine out of 1/2' birch plywood. This matches the height of the rest of the cargo area. (2'x4' ply from Lowes) have to piece rear 2" or so to get full depth. Gorilla Glue ! Inexpensive matte- black spray paint .All-in for under $50 25 for wood, 17 for the hinge 8 for the paint.Hi, I am new to the forum can anyone help my 2020 kia soul didn't come with a cargo panel and I was wanting to make my own ..does anyone know the measurements including thickness of the board I should use ....thank you just trying to get ideas
