I thank you very much for this. I feel much better now that I know that I wasn't loosing my mind. Injoy the rest of your day.Pulls up as a 2.0 when I punch in your VIN in KGIS
Righteous man. Now all's I need is the full vehicle wireing scamatics and I'll be golden. Lol thank you.Here's something that might interest you !! The original Window Sticker as delivered to the dealership that sold your car.
Lots of info there..Enjoy
H
Oh, and spongebob got to me too, LOL !!
If you could send that in Morgan Freeman's voice I'd be driving Miss Daisy.There's wiring schematics online but I obviously have access to the factory diagrams if you need something specific
Electronic door locking systems and reverse wire leaving fuse box.If you could send that in Morgan Freeman's voice I'd be driving Miss Daisy.
Have you heard anything about the camshaft position sensor's causing battery drain when car is off?Electronic door locking systems and reverse wire leaving fuse box.
Not locking up. Just battery draining when car is off. Code po340. Camshaft position sensor or it's wires. All harnesses solid.I have not heard of the solenoid causing battery drain. It's not energized when key is off. If you have a battery drain issue I will post it up later but there's a under $50 amp clamp that I bought on Amazon that works fantastic and reads down to miliamps.
What sort of locking issue are you having. There's several ways to test some of the stuff so it would be better if I knew which diagrams to start with? What's up with reverse lights?
B.u.
Camera 12v on power. After market. Already installed just need reverse signal wire. Ran everything threw the existing camera wires. Just need that power.
