1 - 3 of 3 Posts
I did an install of an aftermarket radio. Hooked up a new backup camera then discovered that my reverse lights DO NOT turn on. Put the e-brake on, put it in reverse and used my volt meter to confirm that the lights are dead. Not even hot. They just don't turn on. Checked fuses (I don't know which fuse to check) -but all the one's I used to power my backup camera were fine.
Does anyone know what to check? What to fix?
There is a signal wire to the radio from the reverse lights for the cars equipped with the back up camera. Since he mentioned installing a radio that's where I would look, see if he grounded it or something
1 - 3 of 3 Posts
