1 - 14 of 14 Posts
First off, does the Soul in any market for gen 3 have a rear vent?
If not, anyone ever just put an appropriately sized vent and/or USB from a used car cut and glued into the center console for the rear passengers?
I figure even if it turns out there's no easy access point to run a insulated tube from the front to that vent, you could install any old USB powered fans and somewhere else give it a little intake, and at least have some air blowing on rear passengers that looks factory, unlike those headrest battery powered fans you see on Amazon, lol!
For example for $30 or so (like below) you could get a used console vent from another vehicle, cut a hole appropriate for the center console and use a black adhesive, and then just put a high flow appropriately sized fan behind it.
Vehicle Grille Automotive tire Motor vehicle Car
I googled, but most results were for base trims of vehicles just putting in the center consoles from upper trims and nothing for the Soul.
You already have duct work under the seats.
Most cars have that, but its usually intended to bring heat to the rear, since hot air rises. But since cool air sinks and its by the toes, they won't really get any cooling effect from the breeze or from the cold air except on their tootsies. :p
Discussion Starter · #7 ·
Half of my posts are not showing up on here.
I can see all your posts. Well, for the past few weeks its been 100oF+ in the shade everyday, heat index even higher, so cooling is important. Worst case scenario, they look a bit ghetto, but for a few bucks I can throw one or two of these for the back passengers on the back of the headrest:
Photograph Light Blue Automotive design Product
Its just not as professional looking.
Those pics are worthy of a good laugh. I can see the rear passengers having all their hair ripped off by multiple cuisinarts. The two front dash grills are meant for air distribution to the rear seat.
Discussion Starter · #10 ·
They're usually not that powerful and have a grate so won't be lopping off fingers or anything. Fronts can kinda do the job, but most of the time you won't feel much circulation if sitting behind the driver and passenger, and just the flowing air helps a ton. Not bueno in Texas lately!
World Ecoregion Art paint Nature Orange
Just saw them on the internet and think they would be effective. At first I thought they were mounted on the rear seat headrests. And they are not expensive. Good idea!
Wheel Peripheral Automotive tire Car Product
Thank you, JSmith. for an idea that might work. I’m ordering a pair for my rear passenger. He likes the window open, winter and summer, like most dogs. So I hope the fans will satisfy him as well as myself. It’s not as hot in Northern Michigan as it is in Texas but the winters are cold. Heating or cooling a car is not effective with a wide open window. (What an illuminating scientific prognostication)
Dog Plant Dog breed Carnivore Sky
Shades on rear lateral windows will diminish the solar heat gain. Put the AC in Recirculate, not on outside air, this way the temperature in the car will eventually mix up and be uniform.
If you keep windows open, then you are trying to cool the Universe....
1 - 14 of 14 Posts
