1 - 9 of 9 Posts
So got in my car and hear a strange noise pulling out, get out and see the rear passenger tire is really low, change it and see a good size sheet metal screw stuck in it.
I was just wondering about getting it repaired. Its in the treads not the shoulder or firewall so its a candidate for repair. Im just not sure how safe or reliable the tire would be afterwards. Is there a bigger risk for blowout etc... I drive on highways a lot to work. Anyone have a tire repaired and have any feedback on it? Basically is it a safe and reliable way to go.
Its on my summer wheels which I just bought last year so they probly only have 5k miles on them.
Absolutely can be done. Usually patch or plug from the inside out. All depends on the damage and condition of the puncture. I have successfully repaired auto tires w/ no issue. Motorcycle tires...thats a whole other ball of wax for me.
Thanks for responses.
I planned on taking it to a shop to do it as i read they do the internal sealing.
I was just worried about the safety/reliability as in past i would just have them change tire when i got a flat but splurged on some aftermarket wheels and tires are pricey.
Ill bring it to a shop next week get it patched. I always carry a full sized spare so im good to drive til i get there
For drywall screw-sized holes, I usually fix them myself with the standard outside-in plugs unless the weather's bad and I don't feel like doing it myself. I've yet to have a problem with those repairs. The most important part is cleaning the hole. If you do that right, the repair should outlast the tire, in my experience.
For anything bigger than a drywall screw, I'd bring it to a tire shop.
I repaired a hole from a stud the size of my finger. Needed a double plug to not leak slowly but it worked! Was good for over 5k miles when I got new tires installed due those having traction problems in the rain, etc.
1 - 9 of 9 Posts
