I have a 2012 soul! AT.
from what i understand most of the newer souls have the same inhouse 6 speed auto, so transmission won't be a compatibility issue with newer engines such as the 2.0 sonata Turbo engine.
does anyone have any information about engine placement in our cars? which engines will fit in the soul? which engines have the motor mounts in the right places to be compatible without much work?
from what i read from the search tool in this forum, u would be looking for a FWD engine using the same transmission, there is the 2.4L GDI sonata engine that pushes 198HP there is the 2.0T and there is even the forte 2.4l which i believe is hte same as the sonata except it only gives u 175. (i think).
can anyone confirm if the 6 speed AT transsmission is the same? and what would fit, and engine mounting compatibility?
2012+ engines only, as i would like to stay CARB legal. and u need a newer engine to swap with in order to stay legal.
