you do not need fuel cleaners in todays cars they run way to efficient these days to do this i am a hyundai tech and have had alot of these cars apart and all look clean as if they where new the only time i would recommend a fuel cleaning is if it had an egr
If your engine wasn't lubed properly you would have issues. Instead of the Lucas Oil, use Synthetic oil instead. That's what i will do at my first oil change.
i hear a little rattle if i get on the gas in the low RPM's... so i just changed my driving habits and kept my RPM's up a little bit with my normal driving...
This happens to me too, I drive the Sport M/T. The rattle when getting on it a little, goes away when I use higher grade gas. Maybe Souls need better knock sensors??
If your engine wasn't lubed properly you would have issues. Instead of the Lucas Oil, use Synthetic oil instead. That's why i will do at my first oil change.
Not sure I have a problem here but wanted to throw it out there. I was looking around under the hood with the car running and I found the upper end of the engine to be noisy. I am usually deal with older GM V8s so I might be out of the loop here but if my Soul had a 350 in it I would be popping the valve covers to take a look and re-set the lash. It sounds like an industrial sewing machine right around 1890. Sadly I don't know another local Soul owner to compare with or some one that has a car with the beta II engine in it. Makes me nervous with the light weight oil and all that noise.
Thoughts?
So what did you find out. I had service done at the dealership 2x's after 5000 miles so I am due again the oil was down a full quart after 12000 miles it looks burned on dip stick I added a pint of Lucas oil treatment and the ticking stopped now it is starting again after 1500 miles. I doubt they changed the filter and o the 2nd time...wow
At my 5000 mile oil change I was told it was "normal" to be 1 1/2 quarts low. I have a 2003 that has243000 miles on it and never is low on oil.
I park in the garage and there is no leaks after 14000 miles...I need to change the oil every 3000 miles, I guess. The viscosity breaks down very fast...keep commenting on your situation...they dont make 'em like they used to?
You let the dipstick level fall to 1-1/2 quarts low.
Never let these Korean four cylinders fall more than a half-quart low.
Now the consumption damage is done sooner rather than later.
I've been changing our oils every 3k all-along. No consumption yet.
Most here that report significant consumption issues either waits too long to change the oil - uses thin 5w20... and/or never checks the dipstick level, thus letting the level run too low.
