I know this will come off as suspect given this is my first post so ill try and include as much info as possible.I bought a CPO in late August of this year at roughly 18,900 miles vehicle currently has around 22,300 miles ie same oil.
On 12/4 while driving with cruise enabled at 65mph I felt the car squirm like traction control engaged. I had only enough time to cancel it before the engine konked out and threw a flashing check engine light. While it was physically running it felt as if it were in neutral and without power. It also felt like a strong misfire vibration in the cabin when throttle was applied. Coasted off the freeway and called roadside assistance to have the vehicle towed to Parkside KIA.
All of this occured almost immediately after getting gas which made me suspicious but both corporate for the gas station and state inspectors said the gas was fine.
Monday 12/6 initial diagnostic comes back as bad ignition coil cylinder #1. I escalated to the service manager and GM at the dealership insisting all plugs and coils be replaced but they insisted that #1 was "very bad" and wpuld fix the issue. Since then radio silence. Ive escalated with KIA Corp and the dealer is refusing contact requiring the district manager to get involved and ive filed my paperwork for Autoline to start the repurchase process.
Not sure if mine threw a rod as mine didnt show water intrusion on the dipstick and no visible damage was detected when I looked as it was towed.
Year: 2019
Trim: Base Exclaim
VIN: xxxxxxxxxxxxxxxxxxxxxxxxxx
Mileage: 22,300?
Year: 2019
Trim: Base Exclaim
Mileage: 22,300?
