1 - 3 of 3 Posts
Does anyone know which fuse is for the driver side tail light? Tried looking at the manual but the label descriptions are confusing and didn't see anything about tail lights.
If anyone could point me in the right direction, it would be greatly appreciated!
You don't say what's wrong (just one light on the driver side? everything on that side? both sides?) so we have to be a bit generic (all those lights have different circuits). There doesn't seem to be a fuse specific to that light. If it's just one function, check bulb and socket. If it's (both) brake lights, there's a fuse in the fuse box ("smart junction box") near the driver's left knee. That fuse box has some electronics in it too (don't you love this computerized world, it's apparently responsible for shutting stuff off when the car isn't in use so the battery doesn't run down, the switch should be set to "ON") and is fed by the Body Control Module, which is buried behind the glove box (apparently you have to remove both the radio and the glove box to get to it, ick). At the light, check bulb, socket, and connectors.
1 - 3 of 3 Posts
