I've worked out the thing with the 5 qt oil bottle, like this.
I take 3.5qts of oil out of the 5qt jug, for my first oil change.
On the next oil change I just buy two single quarts of oil of the same brand and weight.
I pour into the engine, the 1.5qt of oil left in the 5qt jug, and then add the two 1qt bottles of oil that I just bought.
At my next oil change, I start off with a new 5qt jug.
Like so many things in life..... it's a PROCESS!
But it's not nearly as complicated as many things we do on a daily basis.
I know that for some folks, changing their own oil, is either too much of a job, or just impossible.
At 71 (almost 72 now) I don't get down, under my car as easily as I used to, or get up either, so I do try to take everything I'm going to need, with me, when I first get under my car. I even pre-lube the seal on the Genuine Kia Oil Filter, before I take it under the car.
The job goes much easier, if you (or I) get everything you're going to need, all lined up before you crawl under the car. The only thing I omitted from the above picture, is the old T-Shirt I use for a grease-rag. There is almost NO way to get the oil filter off, without getting some oil (or maybe a lot of oil) on your hand, so the rag is a very important tool.*
* I also, wipe the surface on the engine, where the new oil filter will mate up with it.
In the past, when I let a dealer or Oil Change place change my oil and filter, I've had three oil filters that were not properly torqued down and leaked.
One of them, put on at Walmart, leaked so badly that it allowed all my oil to leak out on I-75 while I was running about 80mph.
That was not on my Kia Soul, but on a Suzuki Forenza (two cars ago). I never went to Walmart again, for an oil change.
Even on the last oil change done by my Kia dealer, they left oil dripping from the bottom of the filter and nearby framing.
If you look closely, you can see the drop of oil on the bottom of the filter, and on the black frame just to the right.
It would not have taken the Oil Change tech, more than a few seconds to clean that up.
Make a party out of your DIY oil change, not a JOB to dread.
Cheers Mates!
TechnoMage
