1 - 3 of 3 Posts
I watched a video by diode dynamics about their install for this product. I'd need to get to the back of the 12v cig lighter though. Do the cig lighters and usb charging station pull out as one unit or do you have to pull apart more of the center consoul?
Squeeze in on the shifter boot and it will pop loose , slide it up the shifter ,then put your fingers in that hole and pull back gently on the upper console cover , it will pop back away from the dash with the 12v & usb sockets in it and you will be able to get to you wire easily enough .
1 - 3 of 3 Posts
