I would have expected our owner's manuals to advise replacement every 50,000 or maybe 60,000 miles.
This thread prompted my 2 cents
https://www.kiasoulforums.com/145-soul-problems-gen-2/114365-another-burning-oil-thread.html
Kia has an inspection proceedure, per these links
Kia Soul: Emission control system - Maintenance - Kia Soul 2014-2019 PS Owner Manual
Kia Soul: Inspection - Crankcase Emission Control System - Emission Control System - Kia Soul 2014-2019 PS Service Manual
Kia Soul: Schematic Diagram - Crankcase Emission Control System - Emission Control System - Kia Soul 2014-2019 PS Service Manual
Kia Soul: Positive Crankcase Ventilation (PCV) Valve Operation Principle - Crankcase Emission Control System - Emission Control System - Kia Soul 2014-2019 PS Service Manual
Kia Soul: Positive Crankcase Ventilation (PCV) Valve Removal - Crankcase Emission Control System - Emission Control System - Kia Soul 2014-2019 PS Service Manual
Kia Soul: Positive Crankcase Ventilation (PCV) Valve Inspection - Crankcase Emission Control System - Emission Control System - Kia Soul 2014-2019 PS Service Manual
This may not be the main problem, but a new PCV is
(a) easy to access
(b) easy to change
(c) less than $10
Photos of location on my 2019 1.6L attached
To minimize the arguments I seem to get from my 2 cents, the following is quoted from the cars.com link:
The PCV system is seldom listed as a maintenance item, but an old valve that is no longer functioning like it should can cause performance and emissions problems...If the valve doesn’t open and close on schedule, or if any part of the system clogs, the result can be a rough idle, sluggish acceleration or increased oil consumption. Rough idling is commonly caused by bad spark plugs, so problems with the PCV valve are often misdiagnosed. If you have a bad PCV valve, PCV valve replacement could eliminate the problems listed above.
This appears to fit my 2019. It is listed for production models Aug 2016 and after. May be a different design for earlier Gen 2:
https://www.kiapartsnow.com/genuine...5;02=D2;04=1;05=7)&Location=pd:20224A11,26740
For earlier Gen 2, research
https://www.kiapartsnow.com/genuine...ubmodel=&Filter=()&Location=pd:20224B11,26740
(a) easy to access
(b) easy to change
(c) less than $10
