Hello everyone,
I've been having a charging issue and I've been searching on forums for days and haven't come up with a solution so I decided to finally ask.
My alternator was showing a bad voltage regulator at the parts store (battery died while at work one day so I was getting everything tested). Long story short I swapped the alternator out and same issue, then tested the removed alt and everything was fine.
There are no check engine lights on, but the alternator seems to only want to match the power draw of the car (+ like .3amps) If I'm using 10 amps, it's making 10.3 amps, if I'm using 20 amps it's making 20.3. This is resulting in my no charge (more accurately too low to matter charging) situation. Also the junk yard alternator, like the old one, is running 13.3 volts when cranked, as stated I had the old one tested after removal and it tested good.
So far as stated I've replace the alternator
Checked all fuses using ohm meter
Checked ground connections using ohm meter
Checked lead wire from alt to bat with ohm meter
Checked engine ground to random body bolt with ohm meter
Then just for sh*ts and giggles I shaved the paint off the grounds anyway as I kept reading that's a common issue
Also cleaned off the alt to batt posts and the posts on the battery
So far I've got nothing, I don't know if the BCM or ECM controls the voltage regulator and that's my issue, or if it does it on its own, and which of the two could possibly the culprit as I can't find any info on what controls it.
Long story short I'm open to ideas, I bought a battery charger just so I can keep a charge and be able to go to work and back without it dieing over a short period of time, but this isn't a very good long term solution.
Anyone have any ideas what else I should check/replace?
