1 - 7 of 7 Posts
We experience a failure of the air direction switches. This also has the A/C switch to fail and we have no outside temperature display.
Go figure. We've only owned this Soul for 10 days, we bought it used.
If you have a solution or suggestion, I'm looking for opinions.
There was another member with much the same problem with his air flow switch. The dealer wound up replacing the whole assembly but that was under warranty. If you do not have a warranty, try a junk yard for the assembly piece.
Thanks for the quick reply. We are under warranty and have an appointment in two days. I'm just looking for as much input as possible.
Discussion Starter · #4 ·
so far, the solution is replace the system. It will take a week to get the part but Northtown Kia, WNY, will stand behind the repair. Warranty.
Discussion Starter · #6 ·
:eek: Solved. It was a complete replacement of the control panel. It appears they have seen this before but usually it's not a replacement just a software update.
The estimated cost was $500. That was a quick guess by the service man.
I'll continue this thread if needed.
Good, that is twice now in the past month that we have seen this come up.
1 - 7 of 7 Posts
